Newb here...
A couple of days ago I built a brand new PC. Got it up and running, bios menu ready to install windows, before doing so I changed the setting on bios for RAM to D.O.C.P. saved and reset, boot light appeared and nothing showed on screen.
I moved RAM to different slots
I removed the CMOS battery
I linked out the CLRTC, restarted whilst pressing <DEL>
Removed my HDD
Removed extension cables
Plugged my HDMI into my Mobo
Nothing works.
To make matters worse i bought a brand new Mobo thinking the first one was faulty and to my dismay, the exact same problem with the new mobo which means it probably wasnt the settings I changed in bios originally? Cause I havent even got that far with this mobo.
Random - The left side fan on my Aorus RTX 3060, it is running but its RGB lights havent turned on once since Ive been switching on and off, should I be worried about that?
Specs:-
Mobo - Rog Strix B550-F
HDD - Seagate Barracuda 4TB
SSD - Crucial P2 1TB
RAM - Corsair Vengeance 2x16GB
CPU - Ryzen 5 3600
GPU - Aorus RTX 3060
PSU - Corsair RM850x
LC - Rog Strix 240
Please help
*Edit #1*
When I plug my HDMI into my Mobo, the VGA light comes up as well. I should be able to run my PC without plugging into my GPU no?
Removed my HDD
Nothing works.
Specs:-
CPU - Ryzen 5 3600
LC - Rog Strix 240
Please help
*Edit #1*
