Boot Linux from a USB stick?
18 Oct 2002
Edinburgh
Evening folks,
First-time poster in here, long time lurker. Having made a serious error with my Win7 netbook, I'm looking to take advantage and install a dual-boot Linux/Win7 and test drive various distributions for awhile.
At the moment, however, the netbook doesn't boot (Win7 issue - separate) so I'm hoping I can kill two birds with one stone.
Is it possible (I gather it is) to run a Linux dist off an 8GB USB stick, enabling me to save my files? I'd then wipe the HDD, install both OSes and be on my way.
Any suggestions to this effect would be massively appreciated. I'm keen to get started as soon as possible. Thanks!
Unetbootin
Open it up, select a distro, select a drive and click a button.
Does the lot will download and create a bootable flash drive.
Used it many of times on my old Acer Aspire One
Yeah, Unetbootin is all you need. It can grab your selection of distro from its built-in menu, or if the distro you want isn't there, you can download the ISO of it then point Unetbootin at that ISO. Either way, you will soon have a bootable USB drive. :)
You can write a Debian .iso image directly to a USB stick and it'll boot. Can't speak for the other distributions. Cat writes the file onto the raw device, so don't bother formatting the USB stick. There's probably an equivalent windows command.
Code:
cat debian.iso > /dev/sdX
And you're done. The USB stick found at /dev/sdX is now bootable, and you can install Debian from it.
If you're evaluating several distros with a view to an eventual permanent installation, and you have a decent sized flash drive, you could load it up with several live CDs and multiboot using this: http://www.pendrivelinux.com/yumi-multiboot-usb-creator/ :)
Alright, so unetbootin works perfectly. Great little program, I must admit.
However when I switch on the netbook (BIOS modified accordingly), I am constantly presented with "Missing Operating System" and am told to press any key to reboot from the correct boot device.
The BIOS has identified the USB drive (hell, it even has the correct name) but it will not boot. I've tried four different distros (even tried Windows) but the error message is the same.
Full disclosure - I am running Mac OSX and am finding it incredibly hard to make it do what I want. No surprise there. Most of the useful programs are intended for Windows or Linux OSes, and I don't have access to anything but Macbooks at the moment. I could probably use my work computer, but I doubt that would fly with IT.
I've been searching for a tutorial to create a bootable Linux USB pen drive from OSX to no avail. Any suggestions?
Some BIOSes are a bit misleading in the way they handle USB drive booting - rather than selecting USB drive as the first boot device in the main menu, which is the obvious and most intuitive choice, you may need to select the *hard drive* as the first boot device, then look for a USB drive in the HDD submenu and bump it to the top (probably using the +/- keys).
It might not be anything to do with the problem you're encountering, but worth checking out.
I don't want to drag this into a BIOS thread, but now it's not even showing my HDD as an option. This is bizarre. USB stick has Ubuntu 11.04 ready to go, but nothing.
