Hi
I have a gigabyte Z87X-UD3H mobo which seems to be loosing the boot order. Sometimes when I turn on the machine it'll boot straight into windows 7, but other times it says something like "please reboot and select proper boot device".
Currently when this message appears I am going into BIOS and setting the boot order and then saving and exiting which will sort the problem for that boot, or sometimes a couple of boots but then it will loose the config and boot order again. Am I missing something? I am using the latest BIOS version (F7).
My second issue that I've been having is that sometimes when I boot into windows, my external drive isn't listed in my computer but it shows in the device manager. I keep getting a window pop up saying "you need to format the drive in drive :F before you can use it". Up till now I have been safely removing the hardware and then reconnecting it to get the drive to show up.
I started to think that my external drive had some bad sectors or was on it's last legs. I ran a WD diagnostics extended test last night which passed and said that the SMART status of the drive is fine. Any ideas why the external drive isn't always recognized ?
Thanks in advance for any help.
Xenon
Xenon
