Boot order screwed when external HD attached
7 Feb 2008
Surrey
When I boot my PC with my Seagate FreeAgent plugged into the USB - it automatically throws off the boot order which I have set (#1 RAID Setup, #2 Disabled) and tries to boot from the external HD. I have kinda solved this by disabling legacy USB support BUT that means I cannot use any USB devices until the OS is loaded.
Anyway to get around this? When I boot with the external HD attached and check the boot order, the RAID setup doesn't even appear and Seagate FreeAgent is set to #1.
Cheers.
I was gonna say disable legacy USB. Apart from that, maybe check to see if there is a BIOS update that addresses the issue.
