Boot Problem
21 Jun 2004
Reading
Hello again,
I've recently put together the spec below, which has been running fine for 4 days. However I rebooted last tonight as a voice conversation screwed up and kept repeating itself, and when it had finished with the windows loading bar it wouldn't show the welcome screen.
I know the screens there as i've tabbed to the shutdown button, but it just will not show.
I am able to get into safe-mode fine, and later on tonight (at work atm) will uninstall and reinstall the Catalyst drivers. If that doesn't work i'll back up my data and try a fresh install.
Anyone else had this problem before, or know what it may be?
I had the problem on a HP laptop. Tried the usaul safe mode, system restore, last know good config etc. I couldnt be bothered with it, just reformatted in the end (not the best solution but there was nothing on this lappy)
you might have a bit more luck posting in software forum
Ok, so.. uninstalling and reinstalling the drivers fixed the problem. Just hope it doesnt happen again or else I will tell ATI where to stick it. :)
