Boot problem
26 Dec 2004
Midlands/UK
I have XP on C:\ and I installed Vista on D:\
I formatted over the weekend and now I dont have the boot options at startup to get back on to Vista :(
Does anyone know how I can get back onto Vista please ?
Cheers.
Ah good. Set your BIOS to boot off 120 GB WD. It should boot into Vista.
Then download and install VistaBootPro and use it to add your XP drive to Vistas bootloader. Reboot and you should have your boot menu back.
Remember that when you're in Vista, Vista will probably be on C and XP will probably be on D.
These were my settings to add x64 XP to my Vista bootloader. You can move XP to the top of the list if you want XP to be the default OS.
It won't boot from D.
In bios I have "Boot from hard Disk" I cannot choose which Hard Drive.
I tryed unplugging the raptor and that did not work either.
Odd. I'm not familiar with the board or the chipset tbh.
Is the drive listed in the Standard CMOS Features screen?
Hmm looks like i'm buggered hehe
"No, it would impossible to reinstall XP again after you’ve installed Vista and keep the Vista boot manager. The XP install will overwrite your boot sectors. You’ll have to subsequently reinstall Vista because the boot manager is complete overhauled, there’s no way to ‘repair’ it. "
Ahh well, thanks for your help anyways mate.
Si Lad said:
"No, it would impossible to reinstall XP again after you’ve installed Vista and keep the Vista boot manager. The XP install will overwrite your boot sectors. You’ll have to subsequently reinstall Vista because the boot manager is complete overhauled, there’s no way to ‘repair’ it."
I'm pretty sure that only applies when both OS's are on the same drive. It's an issue I came across a while back.
I would boot from the Vista cd and run a repair. It may rewrite the Vista bootloader.
Ahh that was going to be my next question "shall i try repair"
But you already answered it.
Cheers I will give that a go now.
Thanks again.
