Boot-up problem
11 Nov 2009
Essex
Hi OcUK,
I was given a broken netbook to fix from my sister and basically when you switch it on, it passes the MoBo BIOS bit and goes to boot windows. The first thing that comes up is the screen with the windows loading bar (http://i.imgur.com/Rp26J.jpg) but it never passes it.
It did this with XP that it had on it from being bought, I thought it was a windows problem so I did a fresh install with Windows 7. The install went fine and the system can handle the OS (I have it on my netbook too that is the same spec) but it still will not get past the first windows loading screen. I'm thinking hardware problem but haven't got a clue where to go from here. Any help would be awesome!
