Hi there. I am wondering why it is that XP slowly slows down with boot times. I have done the following to try and get it back to "2 scrolls":
1) Update all drivers
2) run defrag c: /b @ the command prompt
3) Disable all unnessessary startup programs and services using msconfig
What else is there left to do. It is a little frustrating that you have a great PC:
-CoolerMaster Ammo 533 Aluminum (No PSU) - Silver
-Antec TruePower Trio 550W PSU
-Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
-Intel Core 2 DUO E4300 "LGA775 Allendale" 1.80GHz (800FSB) - Retail
-Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775)
-GeIL 2GB (2x1GB) PC6400C5 800MHz Value DDR2 Dual Channel Kit (GX22GB6400DC)
-BFG GeForce 8800 GTS OC 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
-Western Digital Caviar RE 320GB 3200YS SATA-II 16MB Cache - OEM
-Western Digital Caviar RE 160GB 1600YS SATA-II 16MB Cache - OEM
-Sony AW-G170AB2 18x DVD±RW x12 Ram Dual Layer DVD-Writer - (Black) OEM
With the CPU @ 3.0 GHz, and still have to wait for XP, running those loading bars accross about 6 times... in the first few weeks on the fresh install it was one and a bit.
Any ideas?
Thanks Guys!
Any ideas?
Thanks Guys!
Mine didnt even get the little blue bar to show more than two/three blocks before it boots
