Bootable usb
4 Jun 2008
Glasgow
Hi all can someone give me idiotproof instructions to make a usb stick bootable. I have tried the hp tool and it wont work thanks..George.
I used this tool to make a bootable Windows 7 USB stick and it worked great.
If you need a fresh copy of windows 7 (ie not one loaded with OEM bloatware if you are using a pre-built system) then you can legally download one using one of the links on this page - just use the windows product key that you already have or is attached to your PC.
Sorry i should have explained OS is Vista what has happened is the msi bios updater said new bios was available and should be downloaded well i did as it said now comp has bother starting up. To boot up most of the time i have to clear cmos ( little button on the back ) then boot up but during boot up bios reports (checksum error) then i select (start windows normally) and it starts so i want to revert bios back to Ver 1.30 but Msi updater wont allow reverting back (stupid software) and i dont have a floppy drive installed so i need to do it this way Thanks George..
