Bootcamp AND Parallels?
Will_3rd said:
You can use both if need be, the latest Parallels build lets you use your Bootcamp partition AFAIK.
Ok so you install bootcamp, get that running, then install Parallels to look at that partition?
yup, this is what I do. Works a treat!
doesn't take 30 mins on boot either to re-find all the hardware :)
