Bootcamp - Missing partition.
22 Aug 2006
Hey all,
My first attempt to install a Windows 7 partition hasn't gone well.
Whilst installing Windows 7 the setup crashed, I restarted my Macbook Pro and there was no boot options available. Booting from my Windows 7 DVD and the start of the Windows 7 install just crashes, booting from my Snow Leopard DVD and the partition I made for windows 7 doesn't exist in the Disk Utility.
I've managed to boot from the OSX dvd into Snow Leopard, version 10.7.4.
Here the Windows 7 partition doesn't show in the disk utility either. :confused:
Ummm, help? :p
I just want to get the partition back and try the install again.
*edit*
Fixed it! Did a bit of googling, I did a NVRAM reset by pressing Cmd, Option, P, R on start up.
Once booted the empty partition reappeared in the disk utility. :)
