Bootcamp on already partition HD
30 Dec 2004
Stoke-on-Trent
I recently installed Sl on my new MB and in my wisdom I split the 120Gb HD into:-
95GB - OSX
20GB - reserved for Bootcamp
5GB - SL Restore
Now when I run the bootcamp assistant is says it wont contitue as startup disk must be formatted as single volume - well bugger me for trying to pre-empt it - so is there any way around this as I don't want to get rid of the SL Restore partition if poss.
(I'll be wanting it for Bootcamp and Parrallels eventually)
Can you not just put your Windows disk in the drive, boot while holding down the option key, select the CD and then install into the empty partition?
