Hello,
I'm having a problem with a BootCamp installation and wondered if anyone could shed some light on to the cause of it and a possible fix.
This is what I've done:
Opened up Bootcamp
Made a 15GB Windows partition
Inserted the Windows 7 x64 DVD
Clicked start installation
Run the windows installation. Everything runs fine up to the enter username etc.
The Macbook then reboots as if to start Windows for the first time and nothing loads. If I have the DVD in it gets stuck on press to boot from DVD and if I take the disc out if just stays on a black screen with a flashing _
I'm wondering if it's something to do with the x64? I've had XP 32 bit bootcamped before but not tried Windows 7 x64. Any ideas?
Thanks
Opened up Bootcamp
Thanks
