I run PFPX and TOPCAT in a virtual machine and they work perfectly. I don't know what Orbiter 2010 is but you certainly don't need a native Windows installation to run PFPX and TOPCAT.
You can. Parallels, VMware Fusion, anything that can boot off a native install basically.I read that you can run bootcamp, then use that Windows install in Parallels. Sounds like a good option?
Which versions of Windows work with Boot Camp 5.1?
Boot Camp 5.1 supports 64-bit, non-Enterprise versions of Windows 7, Windows 8.0, and Windows 8.1.
I should have been clearer. New machines don't support it, so essentially, Apple have dropped support in that they aren't adding support from now on.Really? But the FAQs says it does:
