Bootcamp Vista x64 with VMWare?
Commissario
16 Oct 2002
In the radio shack
I've made a bootcamp partition with Vista x64 Ultimate on it, updated the Bootcamp utility and patched Vista. It all works (and is very quick).
I also have VMWare Fusion installed. I appreciate that if I use it to run the Vista bootcamp partition then performance will be well down on running it natively, but will it work? Does VMWare Fusion support Vista x64? I don't want to break the bootcamped Vista.
Ahh, that's the difference. It didn't play nicely in Fusion once I told it to load the bootcamped partition. I think I'm going to keep it for bootcamp only as I have a small XP Fusion VM for work and stuff like that.
Anyway Bod, how's you and the family? It's been far too long.
Indeed it has my good man, indeed it has. I'm very good thanks. Another little kiddlie now (making two - complete set now). I've been a house husband for the past 4 years :D
Has anyone found out what you look like yet? :D
