Booted PC and it said overclock failed?
Was it stable with those settings? You might need a higher voltage?
Check stability with Prime95 and IBT
Also check RAM timings/voltage are set correctly
Yes it was stable. Shall overclock with the same settings again? Because it was fine for about 3 days?
Edit* Re entered overclock settings. Ran prime95 for 45 minutes until I got BSOD. Max temps were 75.
The error code was 101, seen this before. It means not enough vcore doesn't it? So shall I raise my vcore
from 0.010 to say 0.015?
