- 21 Jan 2011
Hi everyone,
I got a new SSD today and cloned my old C drive on to it so it could be used an my boot disk. This all seemed to go fine, but when I then took out the old SSD and put the new SSD into the old SATA connector, I forgot to plug something in that I had removed to rework one of the wires for some of my fans.
When I pressed the power button I immediately remembered that I'd forgotten to plug it back in, but it was too late, and the machine turned off after about half a second.
I then plugged it back in, tried to boot up, and I get a mangled error message, after seeing the (non-mangled) American Megatrends logo for about 30 seconds (this was normal prior these issue, and quite annoying!)
I've tried removing and re-inserting the CMOS battery, and pushing the reset button on my case (although that just seems to reboot the machine?). The MoBo is a Gigabyte GA-Z77X-D3H.
What are my next (possible) steps to try and fix this, or is this an RMA job?
I've uploaded a few images to Imgur. The red circle is where the connector I forgot to connect is, and the close up is the connector that I forgot to connect. Sorry for the poor lighting; there's not much daylight left so I had to use the flash on my phone. The error seems to read "b a B a B B a a y".
Thanks for any help,
Joseph Duffy
Joseph Duffy
