Booting from USB
14 Jan 2022
Cheshire
I have a MacBook pro 2015 which has a broken screen which would be fine as I can attach an external monitor. ( except of course it was hit and miss as to when to close the macbook screen down to change it over to the monitor ! )
Anyway that would be fine but in my haste trying to delete data off the SSD I deleted the OS !!..dumb I know
Anyway when I booted up it cam up witht ? so I thought ok lets get int recovery mode
However when trying to get into recovery mode with CMD+R or CMD+R+Option I cannot get it to show on the external screen so I cant see anything
In my wisdom I thought I would follow Apple's recommendations and created a bootable usb with a compatible montrery OSX and that boots up great
If I use the disk utility I can see the 120Gb SSD fine but if I try the Install OSX option on the USB it doesnt see the SSD ..Arrggghhh
Any help please would be most appreciated
p.s. I do have a 2015 macbook air aswell if there is a way for copy an old OSX from one macbook to another
cheers
Here are some pics. They show all the disks I can see using the USB disk utility. The last picture is what I see when I try doing an install..as you can see I can only see the USB hard disk
Images
Try and 'Erase' the (internal) SSD disk from within Disk Utility before returning to the install wizard; sometimes with a fudged disk it'll need that before the install wizard can see it as a useable drive to install (OSX/MacOS) to.
* This is obviously on the basis you don't need any data from the SSD drive.
