The motherboard is question is
Gigabyte GA-G31M-ES2L iG31 Socket 775.
With the stock cooler everything boots up fine, but when I attach my Thermaltake Big Typhoon and switch the computer on nothing happens. I've checked the connections numerous times and everything is (to the best of my knowledge) as it should be.
The only difference I can see is the stock cooler fan is 4 pin and the Big Typhoon fan is 3 pin going into the 4 pin slot on the motherboard. Would/should/could this be making a difference. The Big Typhoon worked fine on my old Asus P5B Deluxe before that died.
