hello the forum,
hope you and yours are ok during this torrid time in our lives
so first the specs
i7 8700k (OC 4.6ghz) cooled by silverstone tundra superslim 240 AIO with Noctua NF-A12x15 FLX 120mm 1850RPM Fans
Asrock Z390 phantom gaming itx MB
16gb corsair vengance pro rgb 3000mhz (not OC)
PSU fractal design ION SFX 650w fully mudular
EVGA 970 GPU
Inwin A1 plus case
so the issue i am having is that the build rfuses to boot first time on a cold start,if i leave it for a day and come back to it i have to reboot by holding the power button to turn off 3-5 times before it will boot correctly and then it runs smooth as
your knowlege in this field would be much appreciated
so first the specs
EVGA 970 GPU
Inwin A1 plus case
