Hi,
Built a new system this week (spec below). Started up fine, installed win7 fine, installed programs etc fine. Turned the computer off and thats when the problems started.
If i try turn it back on straight after shutting down the first time i hit the power button the fans move a little then stop, then no matter how many time i press the power button nothing happens.
To solve this i have to unplug the power cable, switch the PSU off, then plug everything back in again and it starts up. Ive tried switching the power switch cable around to make sure i have positive and negative correct, same thing happens.
After i unplugged the cable from the wall (still plugged into PSU) i put my hand on the pins of the plug and got an electric shock.
Any help as to what the problem may be would be much appreciated.
Spec:
ATHLON II X4 630 AM3 2.80GHZ 4MB CACHE
4 GB DDR3 1333MHZ CL9 TEAM ELITE kit 2x2
A785G SAM3+ DDR3-1800 OBV GbE FWIRE HDMI
8400GS 256MB DDR2 PCX 64BIT DVI/VGA HDCP
SAMSUNG F3 500GB SATA2 16MB 7200RPM
22X DVD-RW SATA BLACK LIGHTSCRIBE OEM
EVO LABS 700W MODULAR HE 8PIN 4xSATA RB
WINDOWS 7 HOME PREMIUM 64BIT OEM
E2236SWA 21.5" LED LCD TFT M/M BLK
Spec:
