Booting Problem
Caporegime
25 Jul 2003
FR+UK
If I can just refer you to this thread:
On my main PC at home, I have two internal hard drives, a Seagate 500GB disk and a Maxtor (I think) 1TB disk.
A long while back, whilst I was an intrepid explorer, new to the shores of Vista 64, I had a PC crash and reboot, whilst it was applying updates. I had to rescue the install using the dvd and repair it which it did just fine.
Ever since that fateful day, upon booting, and after posting the computer halts with "Error - Operating System not Found".
http://forums.overclockers.co.uk/showthread.php?t=17986921
I'm not sure where the problem lies, but I'm pretty sure it has to be independent of Windows (albeit caused by Windows!) and Linux because of the reasons I've detailed in that thread.
But to summarise:
  • Computer if left to boot posts, then displays "Error loading operating system" - I have to hold F8 for the boot menu, then select my primary hard disk whereupon Grub loads and I can go from there (Ubuntu/Vista).
Steps I've taken:
  • Removed all other internal & external hard disks
  • Run the Vista install repair utility to try and fix the MBT
  • Reinstalled Grub to try and fix the boot sector
  • Removed all other devices from the boot priority in the BIOS
  • Installed both Vista & Linux to the same hard drive (Primary HDD - Seagate) with the other disks removed
  • Sat around scratching my head, generally getting more and more annoyed.
Hummmm, this sounds like a bios issue (as that error is usually given up by the bios when it tries to boot something). Have you tried to update it to a newer/different version??
Other than that, have you also tried installing Grub onto all you hard drives?? I have a slight problem where by the hard drives occasionally switch them selves around in my bios so i have to have grub on both hard drives to ensure a boot menu turns up. (its a weird one)
I haven't installed grub on both hard drives, I'll give that a go later tonight.
I've stopped short of flashing my bios but it might come to that.
