Booting to a shell / terminal
Permabanned
30 Nov 2008
Manchester
Hey,
I'm after a Linux distro, that's under 512mb's in size.
The sole purpose of it is to run Python scripts that interface with Windows files.
Needs:
Python support
hard drive support (will be going in to the windows partition from boot)
All i need is a terminal, then i can hit: python file.py
That's all, i can't find anything like this. :(
Deb net is 20mb, but that's just the install there's no features to it - the main is 650mb = too big. Tinycore doesn't have the support.
Arch Linux?
The ISOs come in at around 350MB and an installation gives you an extremely barebones Linux install (no window managers but I found internet connection surprsingly easy to get going). Has a nice package manager too.
It has great documentation too - directs you through the installation in a lot of detail.
If all your doing is using it for scripting then it might be worth using vm like virtual box instead
Just get a distro that u can customise the install
