Booting to emergency mode
  • Thread starter Thread starter Kei
  • Start date Start date
Kei
Kei
24 Oct 2008
South Wales
My server with fedora 30 installed keeps booting to emergency mode with the control + D option to carry on to default target. Pressing control D allows it to carry on and boot ok without an issue.
I looked at the journal -xb log and this is the result for all of all fails.
Code:
[kei@KEI-NAS ~]$ journalctl -xb | grep fail
May 06 08:41:50 localhost.localdomain systemd-vconsole-setup[304]: KD_FONT_OP_GET failed while trying to get the font metadata: Function not implemented
May 06 08:41:50 localhost.localdomain systemd-vconsole-setup[509]: KD_FONT_OP_GET failed while trying to get the font metadata: Function not implemented
May 06 08:41:51 localhost.localdomain systemd-vconsole-setup[652]: KD_FONT_OP_GET failed while trying to get the font metadata: Function not implemented
May 06 08:41:52 KEI-NAS systemd-vconsole-setup[710]: KD_FONT_OP_GET failed while trying to get the font metadata: Function not implemented
May 06 08:41:52 KEI-NAS kernel: iTCO_wdt: probe of iTCO_wdt failed with error -16
May 06 08:41:52 KEI-NAS systemd-vconsole-setup[815]: KD_FONT_OP_GET failed while trying to get the font metadata: Function not implemented
May 06 08:41:52 KEI-NAS kernel: [drm] failed to retrieve link info, disabling eDP
-- Subject: A start job for unit dev-mapper-fedora_localhost\x2d\x2dlive\x2dhome.device has failed
-- A start job for unit dev-mapper-fedora_localhost\x2d\x2dlive\x2dhome.device has finished with a failure.
May 06 08:43:22 KEI-NAS systemd[1]: Dependency failed for /home.
-- Subject: A start job for unit home.mount has failed
-- A start job for unit home.mount has finished with a failure.
May 06 08:43:22 KEI-NAS systemd[1]: Dependency failed for Local File Systems.
-- Subject: A start job for unit local-fs.target has failed
-- A start job for unit local-fs.target has finished with a failure.
May 06 08:43:22 KEI-NAS systemd[1]: Dependency failed for Mark the need to relabel after reboot.
-- Subject: A start job for unit selinux-autorelabel-mark.service has failed
-- A start job for unit selinux-autorelabel-mark.service has finished with a failure.
May 06 08:43:22 KEI-NAS systemd[1]: selinux-autorelabel-mark.service: Job selinux-autorelabel-mark.service/start failed with result 'dependency'.
May 06 08:43:22 KEI-NAS systemd[1]: local-fs.target: Job local-fs.target/start failed with result 'dependency'.
May 06 08:43:22 KEI-NAS systemd[1]: home.mount: Job home.mount/start failed with result 'dependency'.
May 06 08:43:22 KEI-NAS systemd[1]: Dependency failed for File System Check on /dev/mapper/fedora_localhost--live-home.
-- Subject: A start job for unit systemd-fsck@dev-mapper-fedora_localhost\x2d\x2dlive\x2dhome.service has failed
-- A start job for unit systemd-fsck@dev-mapper-fedora_localhost\x2d\x2dlive\x2dhome.service has finished with a failure.
May 06 08:43:22 KEI-NAS systemd[1]: systemd-fsck@dev-mapper-fedora_localhost\x2d\x2dlive\x2dhome.service: Job systemd-fsck@dev-mapper-fedora_localhost\x2d\x2dlive\x2dhome.service/start failed with result 'dependency'.
May 06 08:43:22 KEI-NAS systemd[1]: dev-mapper-fedora_localhost\x2d\x2dlive\x2dhome.device: Job dev-mapper-fedora_localhost\x2d\x2dlive\x2dhome.device/start failed with result 'timeout'.
May 06 08:43:27 KEI-NAS lvm[822]:   WARNING: Not using lvmetad because cache update failed.
May 06 08:43:50 KEI-NAS gnome-shell[1541]: g_dir_open_with_errno: assertion 'path != NULL' failed
May 06 08:43:50 KEI-NAS gnome-shell[1541]: g_filename_to_utf8: assertion 'opsysstring != NULL' failed
May 06 08:43:57 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question org IN SOA: failed-auxiliary
-- Subject: DNSSEC validation failed
-- A DNS query or resource record set failed DNSSEC validation. This is usually
May 06 08:43:57 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DS: failed-auxiliary
May 06 08:43:57 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN SOA: failed-auxiliary
May 06 08:43:57 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN A: failed-auxiliary
May 06 08:43:57 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN AAAA: failed-auxiliary
May 06 08:44:04 KEI-NAS gnome-shell[1969]: g_dir_open_with_errno: assertion 'path != NULL' failed
May 06 08:44:04 KEI-NAS gnome-shell[1969]: g_filename_to_utf8: assertion 'opsysstring != NULL' failed
May 06 08:44:05 KEI-NAS gnome-session[1907]: gnome-session-binary[1907]: GLib-CRITICAL: g_child_watch_add_full: assertion 'pid > 0' failed
May 06 08:44:05 KEI-NAS gnome-session-binary[1907]: GLib-CRITICAL: g_child_watch_add_full: assertion 'pid > 0' failed
May 06 08:44:05 KEI-NAS gsd-color[1674]: failed to set screen _ICC_PROFILE: Failed to open file “/home/kei/.local/share/icc/edid-8d4ab794649ceb36b68bda7c5ecbe17f.icc”: Permission denied
May 06 08:44:13 KEI-NAS gsd-color[2231]: failed to connect to device: Failed to connect to missing device /org/freedesktop/ColorManager/devices/xrandr_Ancor_Communications_Inc_ASUS_PA238_B9LMTF055910_gdm_42
May 06 08:44:13 KEI-NAS gnome-session-binary[1518]: Unrecoverable failure in required component org.gnome.Shell.desktop
May 06 08:44:28 KEI-NAS pulseaudio[1884]: E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
May 06 08:46:13 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DS: failed-auxiliary
May 06 08:46:13 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DNSKEY: failed-auxiliary
May 06 08:46:13 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN AAAA: failed-auxiliary
May 06 08:49:18 KEI-NAS tracker-miner-f[2451]: g_str_has_suffix: assertion 'str != NULL' failed
May 06 08:49:18 KEI-NAS tracker-miner-f[2451]: g_str_has_prefix: assertion 'str != NULL' failed
May 06 08:50:15 KEI-NAS gnome-shell[2988]: g_dir_open_with_errno: assertion 'path != NULL' failed
May 06 08:50:15 KEI-NAS gnome-shell[2988]: g_filename_to_utf8: assertion 'opsysstring != NULL' failed
May 06 08:50:15 KEI-NAS gsd-color[2231]: failed to set screen _ICC_PROFILE: Failed to open file “/var/lib/gdm/.local/share/icc/edid-8d4ab794649ceb36b68bda7c5ecbe17f.icc”: Permission denied
May 06 08:50:17 KEI-NAS gsd-color[2231]: failed to set screen _ICC_PROFILE: Failed to open file “/var/lib/gdm/.local/share/icc/edid-8d4ab794649ceb36b68bda7c5ecbe17f.icc”: Permission denied
May 06 08:50:18 KEI-NAS gsd-color[2231]: failed to set screen _ICC_PROFILE: Failed to open file “/var/lib/gdm/.local/share/icc/edid-8d4ab794649ceb36b68bda7c5ecbe17f.icc”: Permission denied
May 06 08:50:30 KEI-NAS gsd-color[2231]: failed to set screen _ICC_PROFILE: Failed to open file “/var/lib/gdm/.local/share/icc/edid-8d4ab794649ceb36b68bda7c5ecbe17f.icc”: Permission denied
May 06 08:50:40 KEI-NAS gsd-color[2231]: failed to connect to device: Failed to connect to missing device /org/freedesktop/ColorManager/devices/xrandr_Ancor_Communications_Inc_ASUS_PA238_B9LMTF055910_gdm_42
May 06 08:50:40 KEI-NAS gnome-session-binary[2973]: Unrecoverable failure in required component org.gnome.Shell.desktop
May 06 09:34:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DS: failed-auxiliary
May 06 09:34:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DNSKEY: failed-auxiliary
May 06 09:34:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN A: failed-auxiliary
May 06 09:39:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DS: failed-auxiliary
May 06 09:39:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DNSKEY: failed-auxiliary
May 06 09:39:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN A: failed-auxiliary
May 06 10:54:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DS: failed-auxiliary
May 06 10:54:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DNSKEY: failed-auxiliary
May 06 10:54:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN A: failed-auxiliary
May 06 11:42:37 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DS: failed-auxiliary
May 06 11:42:37 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DNSKEY: failed-auxiliary
May 06 11:42:37 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN AAAA: failed-auxiliary
May 06 12:37:37 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DS: failed-auxiliary
May 06 12:37:37 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DNSKEY: failed-auxiliary
May 06 12:37:37 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN AAAA: failed-auxiliary
May 06 14:19:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DS: failed-auxiliary
May 06 14:19:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DNSKEY: failed-auxiliary
May 06 14:19:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN A: failed-auxiliary
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table mangle --delete LIBVIRT_PRT --out-interface virbr0 --protocol udp --destination-port 68 --jump CHECKSUM --checksum-fill' failed: iptables: No chain/target/match by that name.
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table nat --delete LIBVIRT_PRT --source 192.168.122.0/24 --destination 224.0.0.0/24 --jump RETURN' failed: iptables: Bad rule (does a matching rule exist in that chain?).
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table nat --delete LIBVIRT_PRT --source 192.168.122.0/24 --destination 255.255.255.255/32 --jump RETURN' failed: iptables: Bad rule (does a matching rule exist in that chain?).
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table nat --delete LIBVIRT_PRT --source 192.168.122.0/24 -p tcp ! --destination 192.168.122.0/24 --jump MASQUERADE --to-ports 1024-65535' failed: iptables: No chain/target/match by that name.
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table nat --delete LIBVIRT_PRT --source 192.168.122.0/24 -p udp ! --destination 192.168.122.0/24 --jump MASQUERADE --to-ports 1024-65535' failed: iptables: No chain/target/match by that name.
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table nat --delete LIBVIRT_PRT --source 192.168.122.0/24 ! --destination 192.168.122.0/24 --jump MASQUERADE' failed: iptables: No chain/target/match by that name.
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table filter --delete LIBVIRT_FWI --destination 192.168.122.0/24 --out-interface virbr0 --match conntrack --ctstate ESTABLISHED,RELATED --jump ACCEPT' failed: iptables: Bad rule (does a matching rule exist in that chain?).
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table filter --delete LIBVIRT_FWO --source 192.168.122.0/24 --in-interface virbr0 --jump ACCEPT' failed: iptables: Bad rule (does a matching rule exist in that chain?).
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table filter --delete LIBVIRT_FWX --in-interface virbr0 --out-interface virbr0 --jump ACCEPT' failed: iptables: Bad rule (does a matching rule exist in that chain?).
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table filter --delete LIBVIRT_FWI --out-interface virbr0 --jump REJECT' failed: iptables: No chain/target/match by that name.
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table filter --delete LIBVIRT_FWO --in-interface virbr0 --jump REJECT' failed: iptables: No chain/target/match by that name.
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table filter --delete LIBVIRT_INP --in-interface virbr0 --protocol udp --destination-port 53 --jump ACCEPT' failed: iptables: Bad rule (does a matching rule exist in that chain?).
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table filter --delete LIBVIRT_INP --in-interface virbr0 --protocol tcp --destination-port 53 --jump ACCEPT' failed: iptables: Bad rule (does a matching rule exist in that chain?).
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table filter --delete LIBVIRT_OUT --out-interface virbr0 --protocol udp --destination-port 68 --jump ACCEPT' failed: iptables: Bad rule (does a matching rule exist in that chain?).
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table filter --delete LIBVIRT_INP --in-interface virbr0 --protocol udp --destination-port 67 --jump ACCEPT' failed: iptables: Bad rule (does a matching rule exist in that chain?).
May 06 18:13:46 KEI-NAS firewalld[1030]: WARNING: COMMAND_FAILED: '/usr/sbin/iptables -w10 -w --table filter --delete LIBVIRT_INP --in-interface virbr0 --protocol tcp --destination-port 67 --jump ACCEPT' failed: iptables: Bad rule (does a matching rule exist in that chain?).
May 06 18:14:57 KEI-NAS dbus-daemon[18548]: [session uid=1000 pid=18546] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 18:14:57 KEI-NAS dbus-broker-launch[18595]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 18:14:58 KEI-NAS dbus-daemon[18548]: [session uid=1000 pid=18546] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 18:14:58 KEI-NAS dbus-broker-launch[18595]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 18:14:58 KEI-NAS gnome-shell[18626]: g_dir_open_with_errno: assertion 'path != NULL' failed
May 06 18:14:58 KEI-NAS gnome-shell[18626]: g_filename_to_utf8: assertion 'opsysstring != NULL' failed
May 06 18:14:58 KEI-NAS pulseaudio[1884]: E: [pulseaudio] module.c: Failed to load module "module-x11-xsmp" (argument: "display=:1 session_manager=local/unix:@/tmp/.ICE-unix/18538,unix/unix:/tmp/.ICE-unix/18538"): initialization failed.
May 06 18:14:58 KEI-NAS pulseaudio.desktop[18850]: Failure: Module initialization failed
May 06 18:14:58 KEI-NAS gnome-session[18538]: gnome-session-binary[18538]: GLib-CRITICAL: g_child_watch_add_full: assertion 'pid > 0' failed
May 06 18:14:58 KEI-NAS gnome-session-binary[18538]: GLib-CRITICAL: g_child_watch_add_full: assertion 'pid > 0' failed
May 06 18:14:59 KEI-NAS dbus-daemon[18548]: [session uid=1000 pid=18546] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 18:14:59 KEI-NAS dbus-broker-launch[18595]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 18:14:59 KEI-NAS gnome-shell[18626]: st_label_set_text: assertion 'text != NULL' failed
May 06 18:15:19 KEI-NAS org.gnome.Shell.CalendarServer[18548]: gnome-shell-calendar-server[18690]: Lost (or failed to acquire) the name org.gnome.Shell.CalendarServer - exiting
-- Subject: Unit failed
-- The unit UNIT has entered the 'failed' state with result 'exit-code'.
May 06 18:15:19 KEI-NAS polkit-agent-helper-1[19079]: pam_unix(polkit-1:auth): conversation failed
May 06 18:15:19 KEI-NAS PackageKit[18764]: uid 1000 failed to obtain auth
May 06 18:15:19 KEI-NAS gsd-color[18827]: failed to refresh: The connection is closed
May 06 18:15:45 KEI-NAS pulseaudio[19164]: E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
May 06 18:20:06 KEI-NAS dbus-daemon[19253]: [session uid=1000 pid=19251] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 18:20:06 KEI-NAS dbus-broker-launch[19300]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 18:20:06 KEI-NAS gnome-shell[19331]: g_dir_open_with_errno: assertion 'path != NULL' failed
May 06 18:20:06 KEI-NAS gnome-shell[19331]: g_filename_to_utf8: assertion 'opsysstring != NULL' failed
May 06 18:20:07 KEI-NAS dbus-daemon[19253]: [session uid=1000 pid=19251] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 18:20:07 KEI-NAS dbus-broker-launch[19300]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 18:20:07 KEI-NAS gnome-session[19243]: gnome-session-binary[19243]: GLib-CRITICAL: g_child_watch_add_full: assertion 'pid > 0' failed
May 06 18:20:07 KEI-NAS gnome-session-binary[19243]: GLib-CRITICAL: g_child_watch_add_full: assertion 'pid > 0' failed
May 06 18:20:07 KEI-NAS gnome-shell[19331]: st_label_set_text: assertion 'text != NULL' failed
May 06 18:20:57 KEI-NAS gsd-color[19510]: failed to get devices: Timeout was reached
May 06 18:30:25 KEI-NAS org.gnome.Shell.CalendarServer[19253]: gnome-shell-calendar-server[19395]: Lost (or failed to acquire) the name org.gnome.Shell.CalendarServer - exiting
May 06 18:30:45 KEI-NAS unix_chkpwd[20100]: password check failed for user (kei)
May 06 18:30:45 KEI-NAS sudo[20096]: pam_unix(sudo:auth): authentication failure; logname=kei uid=1000 euid=0 tty=/dev/pts/1 ruser=kei rhost=  user=kei
May 06 18:30:45 KEI-NAS audit[20096]: USER_AUTH pid=20096 uid=1000 auid=1000 ses=5 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:authentication grantors=? acct="kei" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=failed'
May 06 18:30:51 KEI-NAS pulseaudio[20086]: E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
-- The unit vncserver@:1.service has entered the 'failed' state with result 'exit-code'.
-- Subject: A start job for unit vncserver@:1.service has failed
-- A start job for unit vncserver@:1.service has finished with a failure.
-- The job identifier is 8917 and the job result is failed.
May 06 18:31:33 KEI-NAS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vncserver@:1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
-- The job identifier is 9388 and the job result is failed.
May 06 18:38:51 KEI-NAS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vncserver@:1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
-- The job identifier is 9623 and the job result is failed.
May 06 18:41:09 KEI-NAS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vncserver@:1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 06 18:46:21 KEI-NAS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vncserver@1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
-- The unit [email protected] has entered the 'failed' state with result 'exit-code'.
-- Subject: A start job for unit [email protected] has failed
-- A start job for unit [email protected] has finished with a failure.
-- The job identifier is 9977 and the job result is failed.
-- The job identifier is 10213 and the job result is failed.
May 06 18:48:36 KEI-NAS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vncserver@1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
-- The job identifier is 10331 and the job result is failed.
May 06 18:48:42 KEI-NAS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vncserver@1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 06 18:50:48 KEI-NAS dbus-daemon[20690]: [session uid=1000 pid=20688] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 18:50:48 KEI-NAS dbus-broker-launch[20737]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 18:50:48 KEI-NAS gnome-shell[20768]: g_dir_open_with_errno: assertion 'path != NULL' failed
May 06 18:50:48 KEI-NAS gnome-shell[20768]: g_filename_to_utf8: assertion 'opsysstring != NULL' failed
May 06 18:50:49 KEI-NAS gnome-session[20680]: gnome-session-binary[20680]: GLib-CRITICAL: g_child_watch_add_full: assertion 'pid > 0' failed
May 06 18:50:49 KEI-NAS gnome-session-binary[20680]: GLib-CRITICAL: g_child_watch_add_full: assertion 'pid > 0' failed
May 06 18:50:49 KEI-NAS dbus-daemon[20690]: [session uid=1000 pid=20688] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 18:50:49 KEI-NAS dbus-broker-launch[20737]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 18:50:49 KEI-NAS gnome-shell[20768]: st_label_set_text: assertion 'text != NULL' failed
May 06 18:51:10 KEI-NAS org.gnome.Shell.CalendarServer[20690]: gnome-shell-calendar-server[20831]: Lost (or failed to acquire) the name org.gnome.Shell.CalendarServer - exiting
May 06 18:51:10 KEI-NAS polkit-agent-helper-1[21186]: pam_unix(polkit-1:auth): conversation failed
May 06 18:51:10 KEI-NAS PackageKit[20905]: uid 1000 failed to obtain auth
May 06 18:51:11 KEI-NAS gsd-color[20959]: failed to refresh: The connection is closed
May 06 18:51:36 KEI-NAS pulseaudio[21290]: E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
-- The job identifier is 11391 and the job result is failed.
May 06 18:57:23 KEI-NAS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vncserver@1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 06 19:03:49 KEI-NAS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vncserver@1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
-- The job identifier is 11626 and the job result is failed.
-- The job identifier is 11861 and the job result is failed.
May 06 19:05:20 KEI-NAS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vncserver@1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
-- The job identifier is 12096 and the job result is failed.
May 06 19:08:30 KEI-NAS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vncserver@1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 06 19:13:43 KEI-NAS dbus-daemon[21925]: [session uid=1000 pid=21923] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:13:43 KEI-NAS dbus-broker-launch[21970]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:13:43 KEI-NAS gnome-session-binary[21915]: Unrecoverable failure in required component org.gnome.Shell.desktop
May 06 19:13:43 KEI-NAS gsd-color[22060]: failed to obtain org.freedesktop.color-manager.create-profile auth
May 06 19:13:44 KEI-NAS pulseaudio[22149]: Failed to load module "module-esound-protocol-unix" (argument: ""): initialization failed.
May 06 19:13:44 KEI-NAS gnome-session[21915]: gnome-session-binary[21915]: GLib-CRITICAL: g_child_watch_add_full: assertion 'pid > 0' failed
May 06 19:13:44 KEI-NAS gnome-session-binary[21915]: GLib-CRITICAL: g_child_watch_add_full: assertion 'pid > 0' failed
May 06 19:13:44 KEI-NAS dbus-daemon[21925]: [session uid=1000 pid=21923] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:13:44 KEI-NAS dbus-broker-launch[21970]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:13:44 KEI-NAS PackageKit[22391]: uid 1000 failed to obtain auth
May 06 19:13:46 KEI-NAS gnome-software[22262]: g_object_ref: assertion 'old_val > 0' failed
May 06 19:14:09 KEI-NAS pulseaudio[22149]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
-- The unit [email protected] has entered the 'failed' state with result 'timeout'.
-- The job identifier is 12331 and the job result is failed.
May 06 19:15:13 KEI-NAS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vncserver@1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 06 19:18:50 KEI-NAS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vncserver@:1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
-- The job identifier is 12812 and the job result is failed.
May 06 19:20:23 KEI-NAS dbus-daemon[22680]: [session uid=1000 pid=22678] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:20:23 KEI-NAS dbus-broker-launch[22725]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:20:23 KEI-NAS gnome-session-binary[22670]: Unrecoverable failure in required component org.gnome.Shell.desktop
May 06 19:20:23 KEI-NAS gsd-color[22819]: failed to obtain org.freedesktop.color-manager.create-profile auth
May 06 19:20:24 KEI-NAS pulseaudio[22887]: Failed to load module "module-esound-protocol-unix" (argument: ""): initialization failed.
May 06 19:20:24 KEI-NAS gnome-session[22670]: gnome-session-binary[22670]: GLib-CRITICAL: g_child_watch_add_full: assertion 'pid > 0' failed
May 06 19:20:24 KEI-NAS gnome-session-binary[22670]: GLib-CRITICAL: g_child_watch_add_full: assertion 'pid > 0' failed
May 06 19:20:24 KEI-NAS dbus-daemon[22680]: [session uid=1000 pid=22678] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:20:24 KEI-NAS dbus-broker-launch[22725]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:20:25 KEI-NAS dbus-daemon[22680]: [session uid=1000 pid=22678] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:20:25 KEI-NAS dbus-broker-launch[22725]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:20:25 KEI-NAS PackageKit[23168]: uid 1000 failed to obtain auth
May 06 19:20:49 KEI-NAS pulseaudio[22887]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
May 06 19:35:46 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:35:46 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:35:47 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:35:47 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:35:47 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.bluez.obex' failed: Process org.bluez.obex exited with status 1
May 06 19:35:48 KEI-NAS pulseaudio[27049]: Failed to load module "module-esound-protocol-unix" (argument: ""): initialization failed.
May 06 19:35:48 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:35:48 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:36:13 KEI-NAS pulseaudio[27049]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
May 06 19:36:32 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:36:32 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:37:57 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:37:57 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:42:42 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:42:42 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:44:11 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:44:11 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:44:31 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:44:31 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:44:32 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:44:32 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:44:38 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:44:38 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:44:53 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:44:53 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:44:56 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:44:56 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:45:33 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:45:33 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:45:47 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:45:47 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:46:22 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:46:22 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:46:46 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:46:46 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:46:57 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:46:57 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:47:46 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:47:46 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:47:58 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:47:58 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:48:23 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:48:23 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:48:27 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:48:27 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:48:58 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:48:58 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:58:52 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:58:52 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 19:59:52 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 19:59:52 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 20:02:11 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 20:02:11 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 20:04:46 KEI-NAS tracker-miner-f[2451]:   (Sparql buffer) Error in task 0 (file:///usr/share/applications/MSMStartupUI.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url (strerror of errno (not necessarily related): Resource temporarily unavailable)
May 06 20:04:46 KEI-NAS tracker-miner-f[2451]: Could not execute sparql: UNIQUE constraint failed: nie:DataObject.nie:url (strerror of errno (not necessarily related): Resource temporarily unavailable)
May 06 20:04:46 KEI-NAS tracker-miner-f[2451]:   (Sparql buffer) Error in task 0 (file:///usr/share/applications/MSMUninstaller.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url (strerror of errno (not necessarily related): Resource temporarily unavailable)
May 06 20:04:46 KEI-NAS tracker-miner-f[2451]:   (Sparql buffer) Error in task 1 (file:///usr/share/applications/MSMHelp.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url (strerror of errno (not necessarily related): Resource temporarily unavailable)
May 06 20:19:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DS: failed-auxiliary
May 06 20:19:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DNSKEY: failed-auxiliary
May 06 20:19:08 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN A: failed-auxiliary
May 06 20:28:46 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 20:28:46 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 20:57:37 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DS: failed-auxiliary
May 06 20:57:37 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DNSKEY: failed-auxiliary
May 06 20:57:37 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN AAAA: failed-auxiliary
May 06 21:32:37 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DS: failed-auxiliary
May 06 21:32:37 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN DNSKEY: failed-auxiliary
May 06 21:32:37 KEI-NAS systemd-resolved[1168]: DNSSEC validation failed for question fedoraproject.org IN AAAA: failed-auxiliary
May 06 21:46:44 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 21:46:44 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 21:46:45 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 21:46:45 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 21:46:45 KEI-NAS gnome-software[2437]: not handling error failed for action search: Operation was cancelled
May 06 21:46:46 KEI-NAS dbus-daemon[26738]: [session uid=1000 pid=26736] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
May 06 21:46:46 KEI-NAS dbus-broker-launch[26757]: Activation request for 'org.a11y.atspi.Registry' failed.
May 06 21:46:47 KEI-NAS gnome-shell[1969]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
Rather a lot to go through. The one that I think is triggering it is this:
Code:
fstab looked fine when I checked it, though I can't post it here yet as I'm in work. I've had a look around and there is the suggestion of recreating initramfs using:
Code:
dracut -v -f
What I don't get is it never fails to boot to default target after pressing control+D.
Ran dracut -v -f just for the sake of it. It seems that it's done the trick as it booted straight in to the default target without an issue.
