booting up
22 Apr 2009
Morning all just a quick question, I had a pre build rig delivered two weeks ago and all is fine apart from one small issue, its not a biggie so I'm not to concerned about it. when I boot up windows 7 64 bit from ssd it takes about 3 minutes when the following appears on the black screen.
checking media presence
media present
start pxe over ipv4
halfway through the ipv4 changes to epv6
I know its prob just a simple problem,something I should already know
thanks for your time
It's trying to pxe boot from a network.
Go in to the BIOS and change the boot order to boot from your SSD first.
Boot priority in your bios needs tweaking, set lan to after your cd/dvd and hdds and you'll boot straight up
