Booting XP from USB stick.
basically ive been trying to do this for years and have always failed miserably. i have no need to do it, no use for it, but simply the fact that i have been unable to do it is enough to bug the crap out of me
the guides out there are tedious at best and down write complicated at worst, usually dribbling on about things which you just dont need to know... all that needs to be written is a simple, clear, easy, step by step condensed guide.
to if you can help me install XP on my usb stick come mp3 player, (1 gig) then i will hapilly write up a guide for future ocuk members to use.
cheers.
cheers.
