Bootmgr is missing on start up
21 Dec 2009
Gateshead
I keep getting this error message when I try to load into windows. This problem starts when I am using my computer normally as I would then all of a sudden all the windows will freeze and then a short while after the mouse will stop moving. Then when I reboot I will get the Bootmgr is missing error message, the ssd is then invisible on the bios and the only way I can get around it is to do a clean install. The I bought the Agility 3 last week and so far i've had to do a clean install around 5 times, and I've also had BSODs when tried to boot.
Any ideas?
Thats worked for now mate, thank. Although I do have a feeling its going to pack in again.
Thanks a lot though!
No problem :)
Have you tried running memtest to see if it is an issue with your RAM?
Try taking out the SSD and see if it continues.
Does it happen when there is significant load, or if it is just idling?
Well it wont play dvds now. I havnt tried memtest yet but i'll do that tomorrow.
The drive I use now as my secondary drive was my boot drive on my old computer and it worked fine. So I think its the agility 3. It was at load at that time but not every time. It was really massively loaded anyway, a dvd and a few internet windows + windows xp mode
Everytime I got the missing MBR was when I had another OS installed when I installed Win7 on a SSD. Nice trick, unplug your hard drives before installing win 7, so the install don't put the MBR on the HD.
You can also try a repair install of Win 7, unplugging all drives but the optical and the SSD. It should then install the MBR on the SSD and it should stay there.
Both drives were formatted and had no os on when I installed it though so I dont think it would be that.
Yeah i've done that, it said it detected problems, attempted to fix them but no sucess. I tried what Jordan97 said and after a reboot everything is working. But I think it will happen again.
