Borderlands 2 low fps 7950
  • Thread starter Thread starter IC3
  • Start date Start date
IC3
IC3
3 Dec 2011
I see very strange FPS drops to 10fps! Not all the settings maxed out which is strange since my 7950 1000/1350 should eat this games on all settings maxed out, right?
I didn't play this game for 5-7 months, only just got back to playing again, but I saw this strange fps drop which makes the gameplay unplayable... I did turn down physx to low and turned of FXAA and other settings but didn't help...
Ignore me, I cant read...
Are you able to check what GPU usage % you are getting? If you don't have it already, download MSI afterburner. It has graphs to show you an you can enable and on screen display, so you can see what your GPU is doing. If its somewhere in the 90%'s then that is good, if its lower or very spiky you may have an issue somewhere else.
It jumps from 10% to max of 48% :( I didn't see it go above 50%...
Ok, can you check your CPU usage at idle in task manager and then either check in game if you have a 2nd screen, or run it for a bit and tab out to check.
It's ok now, I guess it fixed it self... Only played for 30-40 minuets and didn't experianced higher drop then 41fps :)
