borderlands ending question
6 Mar 2008
Stoke area
Ok, so I have finally got around to finishing it. Killed the main bad guy, see a cut scene where are bot becomes some assassin-bot and then get a quest to return the key to an NPC which I have done.
Daft question: what now? Just move on to playthrough 2?
I've purchased the DLCs but despite being told I can use fast travel to get there I can't.
hmm you should be able to go to the new dlc its on the load game options if I remember correctly
also borderlands had a terrible ending ;p
Should appear at the normal travel stations. The ending was rubbish but the lead up was good. No worse the Crysis. Why do they do this.
