- 2 Jan 2010
Hiya I'm a bit of a PC novice so bare with me, I might get some stuff completely wrong
I currently have an ASRock ion 330 which just didn't have enough beef for my liking- so I decided to sell it on ebay and upgrade to a small form factor pc. I was tempted to buy barebones and build it myself but my last experience with building a pc was nightmarish- so i'd rather spend the extra few bob and have it pre-built.
Anyways on to the question- i was looking at the "Verso Avenger" on the OC site...
( http://www.overclockers.co.uk/showproduct.php?prodid=FS-195-OK&groupid=43&catid=1446&subcat= )
which seemed to be relatively cheap. I'd use this primarily for a bit of gaming, so I thought i'd add the 4850 card as well. The only thing is, the case only has a 300w power supply- would this be enough? I did a bit of research (IE. I googl'd) and read contrasting things- some sites said I'd need at least a 450w power supply where as others say it only uses around 120w at peak!?
Does anyone have any experience with this card or case and can comment? Would it be wiser to look at an alternative card maybe that has lower power consumption or maybe even get a 450w psu for the case?
Any help is appreciated! Again apologies if I'm a bit clueless
Cheers
Cheers
