What's going on
default is 650:1150:1400As you can see sensor start at normal then drop
Not throttling due to temp or fan.
Had a few BSOD with Afterburner enable on startup.
Have removed it, reinstalled driver after uninstalling previous.
Just noticed it this pm. with FAH taking twice the time per frame
Have installed new version of GPU-Z.
Is it time for a new card or can this one be resuscitated?
, & caused the driver to reset, which crashed a wu @ 45%
. I then needed to reinstall drivers. Seems OK now. Got shaders @ 1548 but still seem to have lost 2 to 3 seconds a frame
