Just put together this rig all @ stock:
A64 3700+
Asus A8N32-SLI
2GB G.Skill HZ PC4000
Sapphire X1900-XT
74GB Raptor
320GB WD SE16
DVR111D
I get 'page_fault_in_unpaged_area' whenever i try to install windows with both sicks of RAM.
Memtest brings up a slew of errors when using both sticks but not with only one (tried both and they check out fine).
I have flashed to the latest BIOS but that did not work... it did however reset all my settings.
Is the MB busted?
Also is the BIOS right in reporting 50'C chipset temps (in a 2x120mm PC7 case with a TT big typhoon)?
Thanks
A64 3700+
Asus A8N32-SLI
Sapphire X1900-XT
74GB Raptor
320GB WD SE16
DVR111D
Is the MB busted?Also is the BIOS right in reporting 50'C chipset temps (in a 2x120mm PC7 case with a TT big typhoon)?
Thanks
