Hi all,
Can anyone offer some advice on a dishwasher problem we're having?
A brief history; Last week our integrated dishwasher (Bosch) threw up an E15 and E23 error code. The E23 code went away as soon as I replaced the pump. Sadly, the E15 code remains; At the end of a cycle, the pump runs continuously even though there is no water left inside the machine. Having taken the side panel off, I can see the plastic container is full of water so perhaps it is trying to empty this?
When the dishwasher is out and tilted backwards slightly, the error code disappears, the pump stops and the machine will run without fault on any cycle. As soon as the dishwasher is positioned upright, as it's meant to sit under the kitchen counter, the E15 error appears.
I'm wondering if it's something to do with the float switch, but I'm not entirely sure where to go from here.
The fact I can make it work simply by leaning it backwards by 5 degrees makes me think it's a simple fix.
Thanks for any advice
