hi all just a quick question, so currently i have the below case on order
https://www.overclockers.co.uk/showproduct.php?prodid=CA-000-XG
and it has a bottom mounted section for the psu , the psu i've purchased is a bequiet one and i ahve never had a case with a bottom mounted psu.
https://www.overclockers.co.uk/showproduct.php?prodid=CA-042-BQ
my question is when i mount this in the case do i flip the psu upside down so that the inside fan points up or do i just put it in as normal as from the look of the case there is ventilation at the bottom of the case .
