Generally the cases with PSU's at the bottom have them in a seperate compartment, which makes rising heat less of an issue. As for wether it makes a real difference... i wouldnt have thought so. The PSU at the top of the case will suck warmer air in the bottom from the CPU/RAM and expel it straight out the back so it's less likely to be swelling around in the case.
I think the location in those tests is coincidence, rather than fact.
That's something done more efficienctly by plain fan.The PSU at the top of the case will suck warmer air in the bottom from the CPU/RAM and expel it straight out the back so it's less likely to be swelling around in the case.
how can the heat rise from the PSU if there is a (in most cases) 120mm fan sucking air down and out?
Moving air from one place to another isn't conducive to removing all heat from the same place. It works as a reduction, but heat will still rise. It takes more than a fan to counter convection.
Pointing the fan on a PSU up or down wont make a difference, as long as there's a gap below the PSU.
The air would still be drawn downwards, because it would move there to replace the air that the PSU would be removing.
Clearly our CAD abilities are beyond mere words. There's nothing in your picture i'm not already well aware of. You understand of course, you could flip that PSU over and have the same effect right?The air would still be drawn downwards, because it would move there to replace the air that the PSU would be removing.
Also, you'll note in my original example at the top, that i mentioned bottom PSU's often being partitioned in seperate compartments, for example in the P180 series; in which case this whole discussion of paint-based retorts is moot![]()
PSU doesn't heat anything above it because air drawn into PSU (where it absorpts heat) by its fan can't go to anywhere else than out from PSU through its rear removing that heat from case.Moving air from one place to another isn't conducive to removing all heat from the same place. It works as a reduction, but heat will still rise. It takes more than a fan to counter convection.
Reason for compartments in P180 is keeping airflow as controlled as possible for minimizing number of needed fans and noise.Also, you'll note in my original example at the top, that i mentioned bottom PSU's often being partitioned in seperate compartments, for example in the P180 series; in which case this whole discussion of paint-based retorts is moot![]()
(and because there's only heat of PSU's losses to be removed fan speed/airflow doesn't need to be high for keeping PSU's components cool)
Only situation when temperature difference based air movement becomes actually significant in PC is when it doesn't have active cooling. (fans)
Best example of convection are cumulus clouds which form when sun heats air near surface and it rises upwards to lifting condensation level where water vapour starts to condense.
I'm sure you've seen many times (or has Homo Sapiens Urbanus gotten that far from real world?) how those clouds starts to rise nicely and you think there's going to be thunderstorm only to see those clouds turn to pancakes ten-fifteen minutes later.
That happens because there's layer of "warmer" air (actually it's only lack of temperature dropping fast enough with altitude) and rising air just doesn't have enough momentum to push through.
(you have lot of capping inversion there in UK)
But what would a mere urbanised human know of such matters?Reason for compartments in P180 is keeping airflow as controlled as possible for minimizing number of needed fans and noise.
Please quote the part where i disputed that.Most efficient (best cooling with least amount of fans) airflow for PC case is front in - back out, holes/fans in everywhere else just messes this by either creating short circuit or drawing air out prematurely leading to lesser airflow for components needing that airflow.
One top exhaust immediately and only directly above CPU can help in maintaining this airflow but anything else won't: One user had 10C CPU temperature drop after making airflow guide which guided intook air toward CPU instead of being drawn out by top exhausts.
