Bought a ER5 1997
23 Aug 2007
I picked this up for £850 and I think I did ok for that price.
The main thing I need is a used rack to mount my top box.
Any mods I should consider doing?
Looks good mate, very clean.
£850 excellent bike for that.
You know the main problem with that bike is that if you look after it, it'll probably last longer than you will.
I know your thinking, wait a minute, that's a bad thing??????
Give it 3 years, 5 years, 10 years.... Then you'll know :)
Could always go for the quick release Givi system which are really well made, but only designed to mount their own range of boxes.
The Shad rack looks like a much stronger design than the Renntec but quite pricey.
Ide probably stick some crash bars on it & a rad protector as well, maybe a fender extender if you plan on commuting on it in all weathers.
