3 Aug 2011 at 12:02 #1 Bengaboy Bengaboy Soldato Joined 1 Sep 2007 Posts 3,902 Glasses as in normal non tinted day to day ones. They are doing my headin, and was wondering if you can change them if you're not happy? Had them for 3 weeks or so.
3 Aug 2011 at 12:05 #2 footman footman Soldato Joined 21 Oct 2002 Posts 4,312 Bengaboy said: Glasses as in normal non tinted day to day ones. They are doing my headin, and was wondering if you can change them if you're not happy? Had them for 3 weeks or so. Click to expand... Take them back, it's possible they've given you the wrong prescription.
3 Aug 2011 at 12:05 #3 Deep Deep Soldato Joined 29 Jul 2004 Posts 6,678 Location Esher If you actually get headaches then you can speak to them and they will probably do what they can to get you the correct prescription
3 Aug 2011 at 12:10 #4 Bengaboy Bengaboy Soldato OP Joined 1 Sep 2007 Posts 3,902 Also wouldn't mind changing the frames , take that would not be possible.
3 Aug 2011 at 12:11 #5 Mr Jack Mr Jack Caporegime Joined 19 May 2004 Posts 34,211 Location Nordfriesland, Germany Go back and talk to them, it may be a wrong prescription or it may be the angle of the lenses or something like that.
3 Aug 2011 at 12:11 #6 Deep Deep Soldato Joined 29 Jul 2004 Posts 6,678 Location Esher Bengaboy said: Also wouldn't mind changing the frames , take that would not be possible. Click to expand... Frames is unlikely, but I suppose if you kick up a fuss you could return both parts and shop somewhere else
