Hi,
I recently bought two 30cm blue SMD LED strips online
They are designed for cars, so I'm assuming they will just have two wires at the end (positive and negative)
So I also bought two molex to sata power cables
Am I right in saying that all I need to do is:
- Cut the sata connector off the molex cable
- Strip the yellow (12v) and black (negative)
- Solder the two wires from the LED strip to the stripped cables (testing them before hand to see which way round I need them)
- Electrical tape the connections
- Plug molex connector into my PSU and turn it on
Few questions:
- Have I mentioned the correct colours?
- Can I connect both strips to one molex connector so it only takes up one space in my PSU?
- It should be OK with my PSU right? I'm assuming so as they won't use much power but best to make sure
Hope you can help, any advice / tips appreciated
Few questions:
Unless you are 100% sure of insulation, the risks is a bit much for the reward. Don't know what ones OCUK sell but if you do a search for SMD LED tape you should you'll find this type. They can be daisy chained very easily and you can run loads off of one molex
