- 28 Dec 2017
- Beds
My main bedroom is reasonably big at 4m x 4m. It's quite a wide span for the joists as the living room below is also that size - so the entire floor is suspended.
It's quite bouncy in the centre of the room and there's a dip of an inch or so across the span. The living room feels much more solid and that has its joists resting on two internal walls below (townhouse so garage/utility underneath).
The house overall is reasonably flimsy and built to the lightest of standards - timber frame walls which flex and move also but that's another story
I'm wondering if the floor will settle once we get all our furniture in and it's weighed down. That said, I'd like it not to bounce so much - things rattle if you jump up and down. I'm considering doubling up maybe two joists spread out across the width? Dividing the floor slab into thirds and strengthening along those lines effectively.
A) Would this add enough strength without being too invasive/impacting other areas?
B) Should I jack the floor up as level as possible before bolting the joists in?
C) Should I also double up the boundary joist that supports the exterior wall? This is a single, and I need to build some reinforcement there anyway as the PVC window is sagging too.
If this sounds like the right route then I can talk with a structural engineer for some calculations and validation. If I'm barking up the wrong tree I'll have to reconsider
