Good evening overclockers.
I'm in the process of doing a little bit of case modding. As you can see I've went for a blue and black theme.
I have one of these NZXT 24-pin pre-braided cables and was wondering what you think I should do with it. Should I just leave it as it is? Do you think it would be worthwhile removing all the braid and heatshrink to then just put different stuff back on?
Also, if I change the braid on it, how do you think I should go about it?
i.e. Make every second wire blue, or every third wire blue? Just wondering what you think will look best.
If you're going to go all out and customise your pc, you may as well re-braid it to the colour theme you want
