- 1 Jun 2012
- UK
Hi i am thinking of braiding my psu cables and doing a bit of a cable tidy, i was wondering about paracord as it is SO much cheaper than the mdpcx stuff.
1. do i need heatwrap with paracord?
2. will the paracord fit correctly back into the psu connectors
3. will 100ft be enough for 2 psus? or should i get a few colours and habe some extra left over
) You will need some masking tape to wrap up the pins in order to pull them through the paracord without them snagging inside. I used 3M 3434 tape and thoroughly wrapped the pins. I also got a long length of 22 gauge tinned copper wire and created a "puller" with a hook on the end which i used to pull more difficult cables through. Make sure your hands are smooth too as rough skin can actually pick at the nylon fibres. You will need a very sharp knife or cutters to cut the paracord cleanly, else it'll fray at the cut. Use a lighter to melt the ends after cutting to make sure it can't fray. There are very good guides on you tube that show you how to do this better than i can describe. (LutroO customs being one i know of)
