Hello,
I have an ageing ASUS motherboard - A68HM-PLUS - FM2+ Socketed motherboard features enduring 5X Protection, high-clarity audio and the new UEFI BIOS on the A68H Chipset
It has this CPU - AMD A6-6400K (FM2, AD640KOKA23HL, rev.A1, 2C, 3.9GHz, L2:1M, HD 8470D, 65W)
Looking at the ASUS site, with the same BIOS this CPU will be compatible - AMD AthlonX4 860K (FM2+, AD860KXBI44JAA, 4C, rev.A1, 3.7GHz, L2:2M, 95W)
https://www.asus.com/uk/Motherboards/A68HMPLUS/HelpDesk_CPU/
I can buy this from eBay - "AMD Athlon X4 860K 3.7GHz Quad Core Socket FM2+ 64BIT Processor 95W CPU" for $18 / £14
Can anybody tell me if going from an A6-6400 (which has 2 cores) to the Athlon X4 860K is likely to work and if it will give an improved performance?
OR will I end up with a smoking pile. The PC is a bit long in the tooth - just thinking of experimenting!
Any AMD gurus out there! Thanks, Mel
