brake disc wear
9 Jul 2009
Moray, Scotland
Time to pick your collective brains... Been told that my front brake disc is looking at the end of its serviceable life. I have no issue with that (other than the cost of a new one) but my question is how can you tell if its worn? I can't see any indicators for wear and haven't got my Haynes manual to hand. Any ideas? Thanks.
Btw its a varadero xl 125 v3
hey gv can you update my trust for the pc? as for the brake disc you need some feeler gaugesto measure the thickness,
If it is heavily worn then there will be a lip you can feel with your finger around the outer edge.
how many miles on the bike?
I get an advisory ever year on my bike due to the brake pads i use being thinner from new than the original pads. Doesnt mean you need a new disc though
