I have just changed the front pads on my bandit and the brake fluid level has risen so there is no visible bubble in the reservoir. Do I need to take some out or is it ok like that?
Just bleed it out with new brake fluid..........................always the best way of dealing with it. Why leave old brake fluid in, that has obviously been topped up.
If the fluid has rose above the max mark in the res after replacing the brake pads.......................then it certainly has been topped up at some point. The point is though, new brake pads.............................just bleed the whole lot through with new fluid. It takes mins and will set you good to go for 1000's of miles.
Yep, I bleed mine at the start of every year, when it comes round to new pads time I just syrange some out of the reservoir til it's near the low mark, stick new pads on and it's usually half full by then.
