Brake Noise
10 Mar 2003
Hi,
Got a weird problem.
Essentially when I head to work in the morning all is fine - no noise. When I return I hit traffic at normally the same place and when I am then in slow moving traffic a noise happens when I apply the brake.
The noise is 36 seconds in on the clip below (apologies for the poor sound - you should be able to hear the noise twice).
Essentially the noise, to me, is a knocking sound. It happens once and the brake applies fine and then it will happen every time the brake is applied there on in (well 80% of the time I'd say).
I'm obviously going to get it looked at but wondered if anyone had any ideas on what it could be.
Brake sound below (again 36 seconds in brake applied twice so you should hear the weird noise twice):
http://www.filedropper.com/brake
M.
