Brake problem
Man of Honour
17 Feb 2003
Chelmsford
When driving the family car yesterday I noticed an intermittent problem with the brakes. After gently applying the brakes at around 40 mph with plenty of time to stop, the car only just carried on stopping just in time.. The brakes only felt 50% responsive.. like someone had put something under the pedal. The first time I thought it was me, maybe catching the pedal wrong but the second time much later in the day was when I coming off the A12 and I thought I was disappearing up some ones back side.. It's a really odd feeling. I've stopped using the car and booked it in Wednesday.. but I'm wondering (being an intermittent problem) and hoping th the garage will pick it up. Just wondered of any of you could give me a few pointers before hand.
Thanks
It's very hard to press.
The problem with intermittent problems is that sods law it won't happen whilst in test.. so you've given me something to go on..
Thanks all
Hi
Car just came back from garage and they came up with the same as what most you suggested.. servo vac or servo ?? The pipe appears to be ok.
However, the engineer said it's difficult to determine which is at fault although he did say it's more likey to be the Servo vac than the servo
Cost for servo vac = £450+vat and the servo £500 + vat + fitting
Not what i wanted to hear.. He said to change the servo vac first see if that works.
Would you agree with this?
edit - just found this on Galaxy Owners Forums
If i remember correctly a way of testing the servo is with the engine not running pump brake pedal until hard then with foot still pressing on pedal start engine if servo is working pedal should move towards floor an inch or so.
http://www.fordgalaxy.org.uk/ford/index.php?showtopic=7296
Someone else with same problem:
http://www.fordgalaxy.org.uk/ford/index.php?showtopic=18401&st=0
Right just tried it.. Pumped brake for a minute, switced engine on whilst foot on brake. Brake pedal went down an inch..
This means it's the vac not the servo right?
Sorry to rejuvenate this thread, but I'm having a few problems and don't know where to turn:
I had instructed my local garage to replace the Servo Vac/Pump upon their inspection on 21st February and the part has been on order with Ford since then. It appears that Ford are having problems finding the part and they have said it's unlikely the part will be available.
The garage have tried looking for alternative parts but to no avail.
The car is still in use but only for essential trips. The garage have passed the car as safe but a few incidents have occurred which have only been avoided by my wifes quick thinking. I have now told her not to use the car.
So I'm stuck with a car that i can't use, repair or sell.
I just wondered if any of you could make any suggestions. We've only had the car just over a year so no warranty, not that would have helped in this case.
Thanks
Huddy
