The brakes are going to need replacing on the Cayman soon and as eurocarparts has a whopping 30% of brake products atm and I've got some track days planned so I thought I'd get on the task early.
I know there's a couple porsche owners on here and I'm wondering whether to get the textar discs and pads or the pagid ones (£150 cheaper in total). I'm inclined to get the textar set as my logic is they'll perform better being the more expensive model however there's lots of mixed opinions and claims the pagid stuff is fine as they're the same company as textar and are the OEM parts fitted by Porsche.
Secondly there are two types of front brake sensors "pin type" and "horse shoe type", how do I determine which mine are?
Finally will I need to order damping pads or discs or can I just use the existing ones?
