Hopefully this is the second-to-last problem with the car, after solving the misfiring (dodgy ignition coil).
Basically at high speed, say I'm doing 70, then I come up to a roundabout and slow it down to 30 to approach the roundabout - the braking from 70 to 30 will be very juddery (like going over lots of very small speedbumps very fast - makes a duh-duh-duh-duh-duh noise).
It feels kinda like I'm vibrating my foot on the brake pedal or something. But I'm not.
Anyways, I thought it could be the brakes, but the disks, pads, shoes and rear cylinders have been replaced and the problem still remains. Fortunately that lot needed changing anyway so I didn't waste any money (leaking cylinders, low disks and pads, figured might as well do the shoes while I'm at it). Got new tyres put on by a garage a while ago, and they did the tracking/balance [apparently] while they replaced the tyres. But the problems still there.
So, any ideas from anyone - why could the car be juddering when braking at high speed? It's done it for maybe a year and hasn't got any worse, but it certainly hasn't got any better and I really think I should get it sorted.
It's a '93 corsa incase it makes any difference or is a common problem (haven't got a real car yet
