Brands of GPU’s
18 Feb 2007
London
Hi
I will be attempting to build my first pc in years sometime next year, and I kind of have spec in mind now but I wanted to ask how you lot go about choosing what brand of graphics card to go for, do you just go for the cheapest?
For example I will likely get a 4070ti super, but I’ve seen ones by Gainward, Zotac, Asus, Gigabyte, are they all much the same or is there a particular brand to go for/avoid?
Thanks
Generally I usually just buy whatever's the cheapest at the time.
They're all pretty much the same. Some offer slight overclocks, fancy RGB, water cooling, nicer looking cards, slightly better/quieter cooling etc but the actual performance will generally be within 1% of each other.
A good thing to look out for is the company's RMA process. Some manufacturers make you ship cards back to Taiwan/Singapore etc, where as some have UK RMA centres which can give you peace of mind. There's a thread on here that talks about the different RMA procedures for each
I've had cards from many different brands over the years, Sapphire, Asus, Zotac, Nvidia, Gigabyte etc and I don't think I'd say I prefer one over the other. That being said, I've never had to RMA a card, so my experience with the companies involved has purely been on a product, not a service level.
Ah cool, cheers, looks like all the ones I mentioned have good RMA process and some are dealt via ocuk.
Cheapest with the best warranty is my usual approach, although I would recommend reading up on the individual models you're looking at to make sure there's no issues specific to them.
When buying Nvidia I usually end up with either Zotac or Gigabyte, but do be aware that you need to register within 30 days to get the additional 2 years (for a total of 5) warranty with them. That said, I don't know of any problems with the Zotac 4070 lineup so I suspect you'd be pretty safe going that route.
