Brass Plating
23 Sep 2012
omicron persei 8
Hi Guys
Not sure if this is the best place to put this post but here goes anyway. I have a copper waterblock that I want brass plating but im fnding it hard to find anyware that will do it for a sensible price and allso accept pay pal. Most companys only seem intrested in high quanitys. I have seen that you can get Brass Plating kits but for me I only have one item, I dont see myself using a kit after that and was wondering if anyone has a kit or know anyone with a kit that would consider brass plating a item for me ?. Ofcorse I would pay what ever is needed.
Allso would consider gold plating but needs to be durable.
This is the last major item for my project and its kind of holding things up now.
http://forums.overclockers.co.uk/showthread.php?t=18500417
I'd just search on google and start going through the search results giving each of them a ring to see if they'd do a small item like that for you. The worst they can say is no, and if that's the case simply move onto the next company...
